samary
#1 Posted : Saturday, June 23, 2012 7:52:49 PM(UTC)
samary
help my dryer was working fine it was just given to me and installed yesterday. On my second load of laundrey today the dryer stopped heating. what do i do first to check about the heat
#2 Posted : Sunday, June 24, 2012 4:25:13 AM(UTC)
Here are your parts.
Replacement parts for Whirlpool LER8857EQ2 ELECTRIC DRYER | AppliancePartsPros.com
First thing to check is the power.
The motor runs off of 120 volts but the heater requires the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
