sandyaloha
#1 Posted : Saturday, June 23, 2012 12:41:11 PM(UTC)
sandyaloha
Changed the large front duel burner element. Still doesn't work. All the other burners work. Do you have any suggestions? Thank you.:)
#2 Posted : Sunday, June 24, 2012 1:52:19 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag MES5870AAW RANGE- S/C S/I ELE | AppliancePartsPros.com
Did the new element include the limiter?
If not then the limiter may be blown (open).
If yes then it is probably the infinite control switch.
There is always a slim possibility that the replacement element is no good.
Would be best to check it with a meter.
sandyaloha
#3 Posted : Monday, June 25, 2012 2:44:09 AM(UTC)
sandyaloha
looks like I will need a infinite control switch for the duel large burner. can you help me with a part #. thank you for your help
#4 Posted : Monday, June 25, 2012 3:10:58 AM(UTC)
It is best to call and talk to the parts people as they have up to date info.
I do not work for AppliancePartsPros so the info you see is the same as mine.
sandyaloha
#5 Posted : Monday, June 25, 2012 1:00:26 PM(UTC)
sandyaloha
okay
thank you!
