probably wrong model number this is an exhaust fan for a bathroom Broan is make. size is a square 7 3/4 " per side. it looks like the part number AP3539281 from your site.
However mine has only one speed switch - the part description says 2 speed. . the electric power is good so it seems to be the motor and fan.. i assume this part can be changed as it has a short power cord that plugs into the box.
thanks
Your best bet and cheapest outlet is to go to home depot or Lowes and get a new unit,remove the motor and blade and install it into your old unit. Seen it.
