Maytag LAT9304AAM top loader washer.
Fills but does not agitate or spin. Timer motors through cycle. Checked door switch, fuse and check switch - all OK. Can turn pump pulley by hand, not jammed.
A follow up on this LAT9304AAM.
It will fill, spin and drain, but will not agitate. There are no unusual noises or smells, it just sits there when it is supposed to agitate.
