PineWolf
#1 Posted : Saturday, June 16, 2012 3:58:47 AM(UTC)
PineWolf
Hello. Newbie to the forum here. I am having the same problem (dryer not heating) that is well documented here (THANKS for all the awesome help & info), and I have a question. Before I read the entire info posted, I purchased (from here!) & replaced both the outlet & inlet thermistor. I put everything back together, and same problem. Should I have replaced the blower motor at the same time? Diagnostics state that outlet thermistor, blower motor, and heater need attention. I don't have the tools here to change the transistor, so it looks like I will be buying the whole enchilada. My hesitation is over whether this will be the cure. Help?
PineWolf
#2 Posted : Monday, June 18, 2012 5:56:15 PM(UTC)
PineWolf
No worries - installed a new blower motor today and it is back up and running. Thanks for the helpful info.
(Mods - please delete this thread)
