essiar
#1 Posted : Thursday, June 14, 2012 6:37:18 PM(UTC)
essiar
Water not dispensing from door. Disconnected tubing from coupler below door (behind kick plate), pressed water/ice dispenser paddle and no water came out. I do hear pump in rear of fridge engaging but no water. My only thought is water perhaps frozen in bladder? Any suggestions. Thanks!
essiar
#2 Posted : Thursday, June 14, 2012 7:11:37 PM(UTC)
essiar
Well, after attempting several options including blasting the bladder and lines with a blow dryer, I decided to pull the filter out just for the heck of it. The filter is only a couple of months old so I didn't think that could be the culprit. Lo and behold, a small particle of ice popped out when I removed the filter. Put the filter back in and now it works better than it is ever has! Water is blasting out the door!
