hogman143
#1 Posted : Monday, June 11, 2012 10:50:15 AM(UTC)
hogman143
When the dryer is working, it will start sqeaking loudly, as if something is out of aline. I have sprayed WD-40 onto the center bearing on the back of the dryer, to no avail. The belt seems to be tracking true around the drum and the drum isn't wobbly. It starts off slightly sqeaking but gets louder as the drying continues.
Simon / APP Team
#2 Posted : Monday, June 11, 2012 12:36:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The noise you are describing is typical for the rear bearings or the front glides going bad. There is a small chance that the idler pulley is guilty one.
You need to take it apart and check.
Here are the breakdown diagrams and Replacement parts for General Electric DDE5300BBL Electric dryer | AppliancePartsPros.com
The bearing kit Part number: WE25M40
The front slide kit Part number: WE25X60
The idler pulley Part number: WE12X81
Good luck. Post the results.
Simon.
