kmerenda
#1 Posted : Saturday, June 9, 2012 4:21:04 AM(UTC)
kmerenda
The plastic tubing that connects the water dispenser to the water valve has been chewed through by rodents, close to where the tube connects to the valve. The tube is completely severed, and I'm not sure how to proceed with the repair, now that we have the rodent infestation taken care of. I'm also not sure which part I need for the tube. I'd appreciate any guidance. The fridge model is marked "GE TFX25JR, TFX22JR"
#2 Posted : Monday, June 11, 2012 3:24:57 AM(UTC)
If the cut tubing is on the low pressure output of the valve, you can buy a 1/4 inch section of hose and a plastic coupler at Lowes. If the valve is is a compression fitting type, you may be able to just reconnect it if the tubing will reach.
