Not entirely sure of the age of the stove -- was with the house I purchased.
Was using the regular oven on Thanksgiving (which worked fine). Went to use the triple task oven and it would not heat up at all. Worked fine prior to this.
Indicator light comes on but the triple task oven does not heat. The elements look fine. Everything seems to work fine with the exception of the lower oven not heating.
Thanks in advance for any info.
Steve
Hi Steve, The first thing I would check is the thermal fuse (#23 on the break down diagram). - The part number for the thermal fuse is AP3606259 Gene.
thanks gene
that looks like that fuse is buried pretty deep. any idea how i can get a repair manual or some thing like it to get me started ?
Unfortunately Kenmore does not publish any manuals, but some of them you can by from Sears.
