mwilliams120
#1 Posted : Friday, September 11, 2009 7:23:25 PM(UTC)
mwilliams120
The dryer kept turning endlessly and it puts out no heat. I replaced the timer and the dryer cycling thermostat and there was no change. It still keeps running and no heat! What could cause that?
mwilliams120
#2 Posted : Friday, September 11, 2009 7:26:55 PM(UTC)
mwilliams120
The wife's standing by with her hands on her hips! Help!
#3 Posted : Saturday, September 12, 2009 2:53:59 AM(UTC)
Replacement parts for WHIRLPOOL LEB6200PQ1 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Have you turned the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet check it with a meter.
In this unit the heater and timer motor run on 240 volts, so if the timer is not advancing and no heat in Timed Dry mode, odds are high that you have a problem with the 240. The main motor on the other hand runs on half the line (120 volts)
Next I would check the heater, should be approximately 10 ohms.
Then the thermal cutoff (Item 9 in the "Bulkhead parts" section), should be 0 ohms.
If the thermal cutoff is blown be sure to give the interior a good cleaning including the blower wheel. Also clean and check your vent system.
Note that the cutoff comes with a high limit thermostat and both should be replaced.
