Harrydryer
#1 Posted : Tuesday, June 5, 2012 2:41:44 PM(UTC)
Harrydryer
All lights are lit. The diagnostic test has everything beeping. After reading some other posts I purchased a replacement door switch. This replaced but I have the same problem. When the start button is held you here a click but the dryer does not start.
What part do I need to replace next?
Simon / APP Team
#2 Posted : Tuesday, June 5, 2012 3:27:29 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Please provide the complete model number of the unit.
Simon.
Harrydryer
#3 Posted : Tuesday, June 5, 2012 4:55:52 PM(UTC)
Harrydryer
Part#GEW9250PWO
Simon / APP Team
#4 Posted : Tuesday, June 5, 2012 5:39:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should check three things:
-thermal fuse #59 on diagr.#1
-belt
-broken belt switch #5, diag.#2
Here are the breakdown diagrams and Replacement parts for Whirlpool GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
Harrydryer
#5 Posted : Saturday, June 9, 2012 5:48:37 AM(UTC)
Harrydryer
The thermal fuse us fine tge belt is connected the belt switch i put a tone on it when it is depressed the switch is open and when it is up there is continuity between the poles. Not sure if that proves anything about the switch. now tgat i have the thing completely dismantled anything else i can check? Let me know if you think i should replace the belt switch.
Harrydryer
#6 Posted : Saturday, June 9, 2012 6:46:19 AM(UTC)
Harrydryer
I took the control panel off and under the part which is labeled motor i see a black solder which is burned out i suppose. I can replace the control panel but caused that relay or whatever it is to burn out.
Harrydryer
#7 Posted : Saturday, June 9, 2012 8:01:37 AM(UTC)
Harrydryer
This the solder point that is black
Harrydryer attached the following image(s):
Harrydryer
#8 Posted : Saturday, June 9, 2012 8:02:51 AM(UTC)
Harrydryer
$247.00 is a lot to invest in the dryer for a new board. Particularly if it just blows out again.
Simon / APP Team
#9 Posted : Sunday, June 10, 2012 7:32:35 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Solder this connection. Good chance it will take care of the problem.
Simon.
