user22
#1 Posted : Friday, September 11, 2009 12:22:37 PM(UTC)
user22
Dryer will turn on if the start button is held in but shuts off once the start button is released. If I hole the start button down to make it run it does not appear to be heating. Any ideas on what the problem is?
#2 Posted : Saturday, September 12, 2009 3:54:30 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%203979101.pdf
Try to get into the diagnostics.
Check the Motor Relay's coil for continuity.
