I noticed this weekend that my dryer is not getting hot and runs forever. Does anyone out there know why?
You seem to be missing the first 3 digits of your model number. Sears numbers are usually 3 digits, a period and the 6 to 8 more digits. No heat can be a power problem, a blown heater coil, a bad timer or a blown thermal cut-off.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. |
THIS FORUM IS DEAD!!!!!!! |
