danielle92273@yahoo.com
#1 Posted : Tuesday, January 22, 2008 2:42:39 PM(UTC)
Groups ready for retrieval: Registered
My washer won't stop filling up. It overfills on all water levels. The wash cycle won't start.
kawfeeman
#2 Posted : Tuesday, January 22, 2008 8:32:32 PM(UTC)
kawfeeman
while filling, if you unplug machine, does water continue to fill machine ?
#3 Posted : Thursday, January 24, 2008 8:39:04 AM(UTC)
When I unplug the washer, it doesn't continue to fill. The water stops.
kawfeeman
#4 Posted : Thursday, January 24, 2008 8:44:25 AM(UTC)
kawfeeman
need to check clear plastic tube from tub to pressure switch, make sure it is intact and to air leaks .. then need to make sure level control clicks while filling ( blow into it ... sounds weird , but we do do that ... ) ( make sure no lint / soap build up in level control tube .. )
#5 Posted : Thursday, January 24, 2008 9:07:25 AM(UTC)
The control knob clicks on each water level while the washer is filling. I blew on the plastic hose and air slowly leaks back out. When I blew into it, I could hear bubbles in the washer.
