I have a maytag washer that filled now it will not do anything. I have checked for power and I have it to the door safety switch. The switch has 4 wires going to it. Should I have continueity, with the door close acrossed the black and red wires. How do I test the safety switch, and the timer?
Groups: APP Team
Hi. With the lid closed continuity as follow - Black to Red, White to Yellow, Red to Yellow. Check the fuse if there is one. (It's optional). Check if you can hear a click (from the lid switch) when you close the lid.See if the switch actuator is engaging the switch. The lid switch Part number: 22003804
