Rank:: Member
The last couple of years our Kenmore side-by-side ice maker fill tube would occasionally freeze. I would thaw and all would be good. Now its doing it daily so no ice will form.
Any suggestions? It is a pretty old model made in 1992.
Groups: APP Team
Hi.
You need to replace the water inlet valve. For the correct part number please provide complete model number.
Thank you.
Simon.
Rank:: Member
Model 9517651 Serial SB2011119 Kenmore Coldspot Frostless 27
Thanks.
Groups: APP Team
Hi. Your refrigerator model number is 106.9517651. The water inlet valve Part number: 4318046
Follow the instructions it's not the same exact replacement. Thank you. Simon.
Rank:: Member
Thanks! Appreciate your help.
Groups: APP Team
You are very welcome.
Simon.
Rank:: Member
I installed the new valve and now I'm not getting water to the ice maker. Any thoughts of what I could have done wrong? It seemed to be a really easy install.
Groups: APP Team
Hi.
Did you defrost the inlet tube?
Simon.
Rank:: Member
Yes sir. Its defrosted. It doesn't seem like water is flowing from the valve to the ice maker anymore.
Groups: APP Team
Switch around the electrical plugs at the water valve's solenoids and push the water lever at the dispenser. If the ice maker starts filling up - than the ice maker is also bad. The ice maker Part number: 4317943
Thank you. Simon.
