Rank:: Member
My rinse aid quit working a few months back. I am trying to find out if there is a wax motor that dispenses the agent or if it is mechanically dispensed through the actuator arm. I opened the front cover and didn't see any motor. I had the inside cover off a few years back and don't remember seeing one on that side either. I also would like to know where the rinse agent is released at inside the dishwasher. I don't know if I have a clogged port or what. I have read where some models the agent comes out the cap. I don't think my model is like this as my cap screws in and it has a bulb at the end that sits in the agent. Any help is greatly appreciated.
Remove the inner door panel and check all actuators and bars and their proper installation. If there is nothing wrong, replace the rinse aid dispenser. The instructions are attached to the reply. - The rinse aid dispenser Part number: 8052027
Rank:: Member
Thank you Gene. It worked for me.
You are welcome. I'm glad you were able to fix it.
