DottieH
#1 Posted : Tuesday, May 29, 2012 1:15:24 PM(UTC)
DottieH
My oven door will not close! It is about 4" from closing so I replaced the hinges and it didn't make a difference, can anyone give me an idea as to why my door will not shut!
Simon / APP Team
#2 Posted : Tuesday, May 29, 2012 1:54:45 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First of all check the positioning of the hinges on the frame.
Check if the hinge plates are not bent(parts in which the hinges inserts.)
Check if the door latch is not in the way.
Thank you. Post the results.
Simon.
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Oven door won't close tightly-has a gap (Oven Repair (including Ranges and Cooktops))
by gloverzoo 3/30/2015 7:45:00 PM(UTC)
Jenn-Aire Oven door won't Close (Oven Repair (including Ranges and Cooktops))
by jgmann 10/28/2014 11:58:22 AM(UTC)
GE Profile Oven Door won't close (Oven Repair (including Ranges and Cooktops))
by TeriT 8/27/2014 10:13:22 AM(UTC)
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11/26/2013 12:22:35 PM(UTC)
Kenmore Oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by ritarandall 9/24/2012 4:00:48 PM(UTC)
Oven door won't close all the way... (Oven Repair (including Ranges and Cooktops))
by RN2010 11/21/2010 1:48:57 PM(UTC)
Oven door won't close right (Oven Repair (including Ranges and Cooktops))
by tsimonsen 5/28/2010 4:23:12 PM(UTC)
Oven door won't close (Oven Repair (including Ranges and Cooktops))
by mhamil1017 4/1/2010 10:07:51 AM(UTC)
Oven Door Won't Close!!! (Oven Repair (including Ranges and Cooktops))
by glenardee 9/28/2009 3:53:40 PM(UTC)
oven door won't close (Oven Repair (including Ranges and Cooktops))
by jeanpier 7/25/2008 11:22:47 AM(UTC)
by hamconsulting 7/21/2008 8:37:21 PM(UTC)
Viking oven door won't close (Oven Repair (including Ranges and Cooktops))
by McDoo 12/3/2007 4:37:00 PM(UTC)
