dziggy
#1 Posted : Monday, May 28, 2012 6:21:42 PM(UTC)
dziggy
need to locate drain hole in freezzer compartment none visable
#2 Posted : Tuesday, May 29, 2012 4:18:09 PM(UTC)
This hole is usually located under evaporator coils. One of the way is to trace the drain tube (#93 at the diagram).
Here are the breakdown diagrams and Replacement parts for General Electric PFS22SBSCSS BOTTOM MOUNT REFRIGERATOR | AppliancePartsPros.com
dziggy
#3 Posted : Monday, June 4, 2012 11:35:35 AM(UTC)
dziggy
ya found 93 in bottom back of frig no visible drain hole on inside of freezer looks like have to remove sliding door panel ,shelves, icemaker,ice maker power panel and back panel of freezer to get to drain area( poor design!) Is it possible to power down freezer for 48 hrs then blow out drain tube from backside to clear drain hole which is i'm guessing is behind back panel below defrost coils.Or remove panel :mad: clear drain and hang piece of #12 copper wire off defrost coil to prevent it clogging again?
#4 Posted : Monday, June 4, 2012 12:20:12 PM(UTC)
Originally Posted by: dziggy Go to Quoted Post
...Is it possible to power down freezer for 48 hrs then blow out drain tube from backside to clear drain hole...
Yes, this is the easiest way.
Defrost drain clogged (Refrigerator & Freezer Repair)
by billkenny 6/4/2008 12:06:04 PM(UTC)
by billkenny 6/4/2008 11:56:51 AM(UTC)
