ljbtexas
#1 Posted : Friday, May 25, 2012 5:04:46 PM(UTC)
ljbtexas
My window unit stopped cooling this afternoon. The digital readout that usually reads the Temp and set desired Temp shows EP. Anyone one know what this code means?:confused:
Johnmatt
#2 Posted : Monday, May 12, 2014 9:14:42 PM(UTC)
Johnmatt
Contact the ac technician for the better solution. It looks like that you need to replace capacitor.
romi77
#3 Posted : Monday, May 19, 2014 9:52:05 PM(UTC)
romi77
Check your thermostat to make sure it is in the "wires are connected correctly" . Ensure the thermostat is set on the appropriate setting
AC not working, chewed wire (Heating, Ventilation, and Air Conditioning (HVAC))
by Mben024 3/16/2017 12:08:52 PM(UTC)
HVAC not working after switching to new digital thermostat?!? (Heating, Ventilation, and Air Conditioning (HVAC))
by gaber79 11/18/2008 9:06:12 AM(UTC)
