Beth R.
#1 Posted : Friday, May 25, 2012 8:59:11 AM(UTC)
Beth R.
This oven came with the house when we moved in, and I've used it reliably for 12 years. I used the broiler today and it worked fine, then, I turned off the broiler. Shortly after that the clock started beeping at regular intervals. W]There was no response when I hit Clear/OFF. Also no response when I tried to turn on the oven, adjust the clock, or anything else. I emailed Hotpoint and got a Chat person who said to flip the circuit breaker for a minute or two.l I did so, but when I turned it back on, the clock started beeping again and still no response.
What might be the problem? Please help.
Simon / APP Team
#2 Posted : Friday, May 25, 2012 10:34:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When it beeps is there any F codes displayed?
If not - then most likely it's the control/clock is bad.The bad news are: this clock is no longer available.
Thank you. Post the results.
Simon.
PS. There is a small chance if you unplug the range for 24 hrs it might work.
