Many of the control panel lights are flashing on my Kenmore dishwasher. Have tried many press button sequences I have read on web sites, but none work. Door frame is clean, have tested overflow sensor, and last but not least have called a repair technician who recommended replacing sensor panel at a cost of $250. I feel confident there is a way to reset this panel. HELP!!!!!
Your model number seems to be missing the first 3 digits. sears numbers are usually 3 digits, a period and then 6 to 8 digits.
To reset the unit either unplug or or flip the breaker off for a couple minutes |
THIS FORUM IS DEAD!!!!!!! |
