I have ordered a replacement detergent dispenser to replace one with a broken latch. If I remove the inside panel from the door does this give me access to replace this part? Is there anything else I need to be aware of? Thanks, Mike
mikewhitetx Yes, removing the inner door panel will give you the access to the soap dispenser mountings. Do not forget to unplug the power cord. - The break down diagrams for the Frigidaire dishwasher Model FDB635RFS4 Good luck. Gene.
