My washer works but it leaks a lot of water underneath what is the problem and how to fix it.
Originally Posted by: helen0000  My washer works but it leaks a lot of water underneath what is the problem and how to fix it. You'll need to remove the front panel and give us a little detail on where you see the water coming from. Once we know that I'm sure we can give some guidance. Below is the machines parts breakdown, which should assist with identifying where you see the water coming from. PAV3300AWW
the black hose is leaking. Please tell me the cost of the hose and the labor to do it. performa maytag Pav3300aww serial # 14941646AA When I took off the front panel there was a black hose under the washer tub that was leaking.
Originally Posted by: helen0000  the black hose is leaking. Please tell me the cost of the hose and the labor to do it. performa maytag Pav3300aww serial # 14941646AA When I took off the front panel there was a black hose under the washer tub that was leaking. If you use the below link you should be able to find the hose you're referring to, a long with a part number and price. Model PAV3300AWW
