Hello all!
I hope someone can help me on this. This washer is leaking from somewhere inside. The problem is I cannot figure out how to open the darn thing. I would like to get the front off for inspection. Any body got any ideas?? Thanks in advance for any help or sugestions!!
5december
[FONT='Times New Roman'] Removing the front is easy simply press in on two clips in-between the front and the top and the front should pull right off. This page has a picture that will help with the location of the clips GE Washer Disassembly Guide[/FONT]
Hello!
Thanks for the help applianceman...it is appreciated!
5december
