I could not find any info on the given model number.
Are you sure it has an "O" in it.
The following parts breakdown is for a JSP41WK1WW.
Replacement parts for General Electric JSP42WK1WW Electric range | AppliancePartsPros.comI look up F2 and on many GE units it is an over temperature fault.
I would stat by checking the oven sensor (Item 253 in Section 1).
Here is a good site with info on it, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.htmlA higher resistance is interpreted as a higher temperature so if the sensor reads OK with a meter also check that the connectors at the board are clean and that the solder connections on the back of the control board are good and that the circuit tracks going to the sensor connection on the board are OK (no cracks). A magnifying glass can help when checking the tracks. You can also put one meter lead on a connector and then trace the circuit board track and check a point further down the circuit to see if it reads 0 ohms.
Bad solder joints are often a duller gray and/or have pin holes. Also gently wiggle the connector while watching the back side of the board to see if the connector leg is moving in the solder.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
