ernel
#1 Posted : Thursday, May 17, 2012 10:50:26 AM(UTC)
ernel
the washing machine completes the wash cycle fine, but when it goes to spin to extract the water, it goes too slow to extract water, maybe 50% of the normal speed. there is water leaking from the bottom and it makes a whining noise. i'm not afraid to try and fix it, but can someone tell me what needs to be repaired please.
thanks
Simon / APP Team
#2 Posted : Thursday, May 17, 2012 11:27:58 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sounds like the drain pump is going bad. I don't know how good you are in DIY but here is the part and the video clip.
The drain pump Part number: 3363394
Good luck. Post the results.
Simon.
ernel
#3 Posted : Thursday, May 17, 2012 11:38:21 AM(UTC)
ernel
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
hi simon, thanks for replying so quickly,
i did replace the pump in december, so i dont think thats it, also, i dont remember it whining when it needed to be changed or it spinning slowly. also, in the tub, there was alot of debris, like when a sink is clogged.
what is that indicative of?
ernel
Simon / APP Team
#4 Posted : Thursday, May 17, 2012 12:17:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the drain pump and drain hose.
Simon.
ernel
#5 Posted : Monday, May 21, 2012 1:10:10 PM(UTC)
ernel
checked the drain pump, turns out my daughters sock some how found its way in there! you were on the money!!!!!!!!
thanks, i had to order in a new pump because the the sock somehow damaged it causing it to leak. thanks a million. you saved us $1800.
my wife was frustated and thats the washer/dryer cost she was looking at!
WHEW!!! that was close. needless to say, we are washing again.
thanks again!
ernel
new jersey
Simon / APP Team
#6 Posted : Monday, May 21, 2012 1:59:20 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
