KD1
#1 Posted : 13 years ago
KD1
Further to question and response below, I had transferred over the jumper when I instlled the new module. But as to your direction to reset the control module by putting it into cancel/drain mode, I can't do that because it won't go into start/run mode. It looks to me like I misdiagnosed the problem since it's behaving exactly as it did before I changed the module. As noted, when powered up I get a flash of the number 88 on the countdown, then all the lights flash a few times, then it goes dark and dead. Any ideas?
Asked by Kd for Model Bosch SHU53
Control panel quit working. When turned on the wash time display flashed random numbers dimly and then all the lights flashed dimly and then stopped. Replaced control module with #266746, powered up and still the same problem - when powered up, did the flashing business and then nothing. Doesn't do anything at all now unless the DW is unplugged and plugged back in. The control module did not come with any programming instructions as referenced in some of the other questions here. Any ideas?
Asked by Kd for Model Bosch SHU5315UC
UserPostedImageUserPostedImage
Hi KD. To reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls. Thank You. Answered by AppliancePartsPros.com
#2 Posted : 13 years ago
What is the complete model number and the serial number of the dishwasher?
KD1
#3 Posted : 13 years ago
KD1
Shu5315uc/u06
Fd7908 06 0080
#4 Posted : 13 years ago
You may want to check the On-Off switch according to the wiring diagrams on the left side scroll down menu Tech circuit diagram uc/u01 replacement parts for Bosch SHU5315 UC/06 (FD 7705-7912) | AppliancePartsPros.com
Also verify the voltage to the dishwasher. Check it with the dishwasher plugged in, connecting the meter probes in parallel.
