teawood
#1 Posted : Tuesday, September 8, 2009 8:46:51 AM(UTC)
teawood
washer has been agitating with tub movement back and forth and no diferance of cycle setting / speed was always the same. Now Ihave no wash or spin. I replaced the open fuse in the wire harnes and still no go.
I get no motor flashing and nor do I know how to initiate it , I have power to the motor and lid switch opens and closes. Help would be welcome Thanks John L Wood 763 424 5882
applianceman
#2 Posted : Tuesday, September 8, 2009 9:07:26 AM(UTC)
applianceman
It has been the tub has been moving during wash the shifter coil is bad. But now if you have power to the motor, the light isn’t flashing and the fuse was blown you have a bad motor. If you replace the motor you will still have a bad shifter coil so you need to replace the sifter coil and the motor. If you ever changed the transmission on the T models changing the shifter is the same. Clothes Washer Repair Guide
teawood
#3 Posted : Wednesday, September 9, 2009 8:33:42 AM(UTC)
teawood
Priced out the parts and bought a new maytag top loader at Best Buy. thanks for saving me from any more trouble. JL Wood
applianceman
#4 Posted : Wednesday, September 9, 2009 5:46:12 PM(UTC)
applianceman
[FONT='Times New Roman']That works Too!! :) [/FONT]
