it glows for about 15 secounds but doent ignite. i double checked the gas so i know its getting gas to the valve. from what ive been reading it sounds like the coils might be bad. i didnt check the fuses yet thou. will post tomarow after i do. any help is much appreciated, i just dont want to get the wrong part. thanks
Rank: Administration
Since the dryer igniter is glowing, the fuse should be ok. I'd replace the coils. 97% bad coils / 3% bad gas valve. - Dryer coils for your Whirlpool. - Breakdown diagrams for Model LG7686XPW0Also, as long as you're in there... Check the belt for cracks, replace if found ( dryer belt). Vacuum any lint inside the dryer.
