george-hanson
#1 Posted : Thursday, May 10, 2012 12:24:18 PM(UTC)
george-hanson
Can not find a way to remove wire retainer on oven lite lens retainer to replace oven light bulb.
Any suggestions would be helpful. Later models of Maytag oven in store simply unscrew lens from oven frame.
Manual from manufacturer says to simply support lens when removing wire retainer so it does not fall. It has no discription of how to gain access to wire retainer to remove it or to show how it is constructed to hold the lens in place. Please help.
George
#2 Posted : Friday, May 11, 2012 3:24:54 AM(UTC)
Replacement parts for Maytag MER5752BAQ RANGE- S/C F/S ELE | AppliancePartsPros.com
Take a look at Item 13 in Section 4.
It is just held on by a spring clip/wire.
Push the center of the clip up, down, left or right depending how the lamp holder is oriented to release the cover.
Guest
#3 Posted : Wednesday, March 30, 2022 8:24:34 AM(UTC)
Guest
Rank: Guest
United States
My wire clip holding the oven light lens has fallen off. Can't get it back on. Any help.
Edited by user Wednesday, March 30, 2022 8:26:45 AM(UTC)  | Reason: Spelling
