My Kenmore undercounter ice maker freezes ice but is not letting the water in to replenish the reservoir and release the ice block to the cutting grid. I replaced the water inlet valve but this did not correct the problem. I wanted to see if there is another part which could cause this malfunction. Could it be the freon temperature sensor? How could I test for this problem? Thanks.
What is the complete model number of the ice maker?
