Intermittently, When I open the either the top or bottomoven door the oven lights go off and on (blink) and LED panel goes blank and Isee a red flashing light appear in the lower left corner of the LED screen. Thetoaster function will not work at all (when I press toast it display “toast”then shuts off). All other baking and range top functions seem to be workingfine. Can you advise? Thank you!
Did you ever find out what was causing this? Mine started doing this today. Originally Posted by: swenson96825  Intermittently, When I open the either the top or bottomoven door the oven lights go off and on (blink) and LED panel goes blank and Isee a red flashing light appear in the lower left corner of the LED screen. Thetoaster function will not work at all (when I press toast it display “toast”then shuts off). All other baking and range top functions seem to be workingfine. Can you advise? Thank you!
Hi, everybody, I am a new friend.:)
