I own a 16 year old Maytag gas dryer model LDG8410AAW that has required very few minor repairs during that time. I just did a complete tune up and replaced the idler wheel, drum belt, tumbler rollers, front bearings, and installed new tumbler seals.
Everything works great, but while working on the dryer I noticed that the tumbler is out of round and is more egg shaped. This of course causes a wobble as the drum turns although it doesn't seem to affect operation of the dryer. A new tumbler costs about $90. Should I replace it to hopefully eliminate the wobble and help reduce wear and tear on the new parts or just leave it alone?
I know some would say just buy a new dryer after 16 years, but to me the new models aren't built as well and I hope to get another 5-10 years out of this washer/dryer set because they were built like a tank. I also did a tune up on the washing machine by replacing the belts, water inlet valve, and replaced a bad lid switch. It still runs as smooth now as the first day we brought it home.
Thanks....! :)
Better to replace the tumbler. When the new one arrives, only allow it to set on end while you have it on the floor. Trying to reshape the old one may work, but all the in and out to test it can get old pretty quickly. You may be able to accomplish it using one or two strap clamps. If you use two, just make sure you tighten them evenly.
Originally Posted by: magician59 Better to replace the tumbler. When the new one arrives, only allow it to set on end while you have it on the floor. Trying to reshape the old one may work, but all the in and out to test it can get old pretty quickly. You may be able to accomplish it using one or two strap clamps. If you use two, just make sure you tighten them evenly. The old tumbler finish is still in fairly good shape, but it does show it's age so it might be best to just replace it. I really appreciate your advice and tips for handling the new part. Thanks....! :)
