amarshall2
#1 Posted : Sunday, May 6, 2012 12:21:52 PM(UTC)
amarshall2
My washer won't fill ..checked water hoses no leaks..electric is fine..it will agitate just wont fill with water any ideas?
#2 Posted : Monday, May 7, 2012 4:14:53 AM(UTC)
Replacement parts for Whirlpool WTW5505SQ1 AUTOMATIC WASHER | AppliancePartsPros.com
See he attachment for the tech sheet.
Sounds like the unit thinks that it is already full.
Could be a bad fill switch (Item 12 in Section 4)
Unplug the unit and the V wire at the fill switch, set the timer to off.
Then measure it with a meter.
V to P should be 0 ohms.
V to T should be infinite ohms.
File Attachment(s):
WTW5505.pdf (291kb) downloaded 8 time(s).
