Hello all, My KitchenAid dishwasher is giving me problems once again. The problem... I select Normal Wash Hit Start The dispenser would click open and door would stay open DW would start filling Dispenser solenoid would hold open during fill and wash cycle Solenoid gets hot to the touch but shows no signs of overheating Cycle would start wash cycle for a few seconds and then stop Open door and close and would start for few seconds and stop Hit cancel and drain DW While I was investigating the dispenser, I pulled the touch pad and noticed the solenoid for the vent was cracked(see attached pic) I assume there is something that makes the plunger move the rubber boot in and out but all that was in the back end is two terminals that the wires attach to sticking up in the broken plastic case. Seems to me that a piston was spit out of the back end and now nothing is in there to work the rubber plunger. It started with a really loud buzzing noise from the dispenser and I used to have to open door and close to restart. It would usually stop buzzing when I did that. The buzzing seemed to have quieted now but maybe because it is on its way out. Any thoughts on this. I really need to get this fixed as Ive put more money into it than I should have. Im into this for a new touch pad, control panel board, gasket set and new latch, all done by a trusted service tech. Now 4 months later its down again. I should have dumped it instead of fixing it but I hate trashing something if it can be repaired affordably. Too many things these days are throw away items.... Please help! Thank You, JR Jr_V attached the following image(s):
Any thoughts on this or should I S-can it and buy a new one? I am so tired of spending money on this and wish I had went for a new one preferably something other than the Whirlpool/KitchenAid line. I just feel that with the money I spent on it would be wasted if I just toss it out....
Any thoughts why the dispenser solenoid would be getting 110v throught the whole cycle from when I close the door till it finished. Now though I can't even get it to go through a whole cycle.
