I had poor water at the dispensor and only half cubes were being made. I changed the water filter and water valve. Now it is making ice properly but I still have slow water at the dispensor. What should I do?
Did you dispense at least 2 gallons of water after you replaced the water filter?
yes we dispensed at least 2 gallons
What is the complete model number of the refrigerator and the part number of the water valve?
Did you check the incoming water pressure?
