igorelik
#1 Posted : Friday, May 4, 2012 11:41:40 AM(UTC)
igorelik
I have Maytag Amana [FONT='Times New Roman','serif']AGR5715QDS stove. The most right knob turns gas OK, but doesnt click the ignitor spark. So I use other knobs to ignite this broken one and it drives me nuts. [/FONT]
[FONT='Times New Roman','serif'][/FONT]
[FONT='Times New Roman','serif']Please help me pick the right part to replace. [/FONT]
[FONT='Times New Roman','serif']Thank you.[/FONT]
#2 Posted : Friday, May 4, 2012 4:24:16 PM(UTC)
Sounds like the problem is a bad ignition switch but there is a small chance for the spark module to be bad as well. I would replace the ignition switch first. If you need the correct part number, post the serial number of the unit.
Here are the breakdown diagrams and Replacement parts for Amana AGR5715QDS RANGE- S/C F/S GAS | AppliancePartsPros.com
igorelik
#3 Posted : Tuesday, May 8, 2012 9:25:07 PM(UTC)
igorelik
Hi Gene,
Range Model: AGR5715QDS
Serial number: 20792078GV
Will wait for your reply.
Thank you.
Igor.
#4 Posted : Wednesday, May 9, 2012 3:11:45 PM(UTC)
Hi Igor,
You have to replace all ignition switches because it comes as the switch harness. It's even better because it will make the repair more reliable.
- The switch harness Part number: 74010630
- The spark module Part number: 12001596
