My washer is not agitating properly, I have changed the "dog,s" before Now it is making a racket I tightened the bolt last week but that did not help it still seems loose and like I mentioned it is very loud.
Thanks James
Originally Posted by: Gene  I have once replaiced the "dogs", last week I removed the inner cap and tightened the loose bolt. The washer is now agitating but it is still making alot of noise. There seems to be some gap or looseness between the upper and lower agitator. I have thew part diagram. Thanks, James
Hi James,
Remove the agitator and check the drive block and the splines.
