Have a older duet that when its starts its so cycle it starts making a bad clunking noise. Other than that it runs fine. Has anybody had this problem and knows what's causing the problem. Thanks
Groups: APP Team
Hi.
Remove the toe panel, remove the rear panel. Observe the belt, the pulley, rear and front shocks.
Good luck. Post the results.
Simon.
