gwheeock915
#1 Posted : Wednesday, May 2, 2012 3:37:56 PM(UTC)
gwheeock915
Hi everyone,
I would appreciate your kind thoughts and expertise in helping me out here. My wife went to start the oven (gas) the other day. After 10 minutes, she went to put in dinner, and nothing.
Not a whiff of gas, a noise, nothing. I have tried the broiler and all settings inbetween and nothing. Like I posted above, the clock, timer, etc. and the cooktop all work.
This is a builders grade GE oven if it helps at all.
Thank you in advance,
Kevin
#2 Posted : Thursday, May 3, 2012 3:39:33 PM(UTC)
Hi Kevin,
Check for 120 VAC to the igniter while the oven thermostat calls for Bake.
If the reading is correct, replace the oven igniter.
- The oven igniter Part number: WB13K21
gwheeock915
#3 Posted : Monday, May 7, 2012 6:45:13 PM(UTC)
gwheeock915
Gene,
Thank you! Up and running again!
#4 Posted : Wednesday, May 9, 2012 2:59:44 PM(UTC)
You are welcome. I'm glad you were able to fix it.
