Our dishwasher recently started leaking from the bottom of the door. Do you think this is a problem with the gasket or something else? Thanks!
I would check the door vent to see if it's plugged up with junk. Open the door and you will see the vent grill on the inside of the door towards the top corner. It just snaps in place. You can pop it out with a flat blade screw drive and then clean the junk out of it.
