I have recently put on a new belt on the dryer, it seems fine but you can't put a heavy load in or the dryer will not run. When it does run with an extremly light load it doesn't run the full course,it will shut off after running for about 10/20min. After it shuts off it doesn't want to start and I have to wait atleast 10/20min maybe longer to even get it to start. I am thinking it could be the motor because when I took it apart there was a lint build up on the motor and through out the dryer. Could it be the motor?
Most likely the problem is a bad motor. - The part number for the motor is AP3094242 Here are the break down diagrams for the Whirlpool laundry center Model LTE6234AW2Gene.
