I'm having an intermittent problem with my oven and broiler . First of all, the cook top works fine but the oven and broiler will not always heat up. When the control is turned to the desired temp. the igniter glows after a few seconds then sometimes you here the gas turn on and it lights . This process may take 55 second or 1.5 min. or not at all. Same prob. w/ the broiler. Any ideas??
