watertoy321
#1 Posted : Wednesday, April 25, 2012 11:29:09 AM(UTC)
watertoy321
My washing machine completes fill and agitate cycles. However, will not spin. I can not hear the motor at all once the agitate cycle is completed. Recommendations welcome. Thank you
Simon / APP Team
#2 Posted : Wednesday, April 25, 2012 12:24:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
The first thing to check in your case would be the lid switch.
To check it remove two screws in the corners of the control panel, lift the top, locate the 3 wire plug going trough the top.
With washer unplugged, install the wire jumper between two outside wires. Turn the washer's spin.
If it work - replace the lid switch Part number: 3949247
See the attached video for the instructions.
Here are the breakdown diagragms and Replacement parts for Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Washing machine won't spin (Washer Repair)
by Mjbruner1 10/3/2013 1:33:04 PM(UTC)
Washing Machine won't spin out water (Washer Repair)
by dlong55 9/29/2013 6:45:30 PM(UTC)
Washing machine won't spin or drain after rinse cycle (Washer Repair)
by brodyn 2/19/2013 7:45:13 PM(UTC)
frigidaire flse72gcs7 gallery laundry center washing machine won't spin (Washer Repair)
by hyperturtle 1/14/2013 8:18:44 PM(UTC)
by Monty Wyne 8/2/2011 11:13:08 AM(UTC)
Washing Machine won't spin (Washer Repair)
by golfer63 6/5/2011 9:03:36 AM(UTC)
Washing Machine won't spin only tries (Washer Repair)
by tferguson1970 5/23/2011 8:25:23 AM(UTC)
hotpoint washing machine won't spin with clothes (Dishwasher Repair)
by Wayne Thomas 5/26/2009 8:03:37 AM(UTC)
washing machine won't spin the water out it (Washer Repair)
by jgosch 5/9/2009 10:58:46 AM(UTC)
Washing machine won't spin or agitate (Washer Repair)
by necibill 3/16/2009 6:42:08 PM(UTC)
by tracyl68 1/13/2009 1:28:10 PM(UTC)
by dejoel 10/23/2008 9:57:46 AM(UTC)
