hello, i have a GE refrigerator i purchased Part # WR49X10180, can someone advise me if the EPS L insert, in the DE AC Ice ball kit, an additional part that has to be installed? or is this a replacement part? I didn't see it when i took off the fresh food evaporator cover. Also, I made a little hole in front of the foam inside the cover by the fan, any suggestions for patching the quarter size hole? Thanks for assisting vagochob attached the following image(s):
vagochob, what did you end up doing with the beverage center duct? I'm in the process of pulling my refrigerator apart and was hoping for better instructions. I have the zfsb23drgss model.
Can you post a picture of the kit after it's been installed?
