muckamoo2
#1 Posted : Saturday, September 5, 2009 6:26:46 AM(UTC)
muckamoo2
When replacing the water valve how should the plugs be attached? One plug has a white wire and a tan wire. The other plug has a white and a blue wire. The valve has been installed, and I do have water at the water dispenser but not to the ice maker.
applianceman
#2 Posted : Saturday, September 5, 2009 8:08:10 AM(UTC)
applianceman
Make sure the plugs are on good, if you get water to the door you don’t have them hooked wrong. Also make sure the tube that enters the icemaker isn’t clogged with ice.
Refrigerator repair guide
