jakdodge
#1 Posted : Monday, April 23, 2012 3:45:42 PM(UTC)
jakdodge
I got the dishwasher used from a friend and i hooked it up yesterday. I did first load of dishes and it worked fine. I did the second load and i found that there was still quite a bit of water still in the bottom. I thought it was plugged but there was nothing. I went to restart it and there wasn't any lights on. Anyone have any ideas
Simon / APP Team
#2 Posted : Monday, April 23, 2012 4:41:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Make sure the dishwasher is getting 120v.
Then unplug it, remove the control panel.
Locate the thermal fuse on the side of the control board.
Using the multimeter check the fuse for continuity. If it's open - replace it.
Read the instructions and replace the wires two.
The thermal fuse Part number: 675813
Part number: 675813
Here are the breakdown diagrams and Replacement parts for Whirlpool DU948PWKB1 DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
