Hi i am Having a problem with my oven not keeping temp @ the right setting. Off somtimes by 50deg intermittently. I have changed the high limit switch and oven sensor. Checked bake element @40ohms The control panel is my next fix correct? Or what else:confused:
Groups: APP Team
Hi. After replacing the oven sensor check the connection between the sensor and the control board. If everything checks OK - replace the control board. Control board Part number: 74008952
