I can't find the service manual that shows how to remove this part. It needs cleaning as scale has built up even with cleaner solutions. I have everything removed down to that one piece and can't see anything that holds it down.
Groups: APP Team
Hi. Follow this directions: Remove racks. Remove Wash Manifold Loosen Wash Arm Hub and Pivot. Remove Spray Arm. Remove 3 Torx™ screws securing Filter Guard. Thank you. Simon.
I got the answer as I used a brush and found both screws... sorry for bothering you with this. Thanks for always helping with these matters.
Groups: APP Team
You are very welcome.
Simon.
